Hello guys,
I have seen this post.
https://community.ptc.com/t5/ThingWorx-Developers/infotable-pivot/m-p/608598#M36084
But I need a function that allows me to pivot an Infotable with only two columns, one of type number and one of type string.
Is there an easy possiblity to do so?
Hi @etc6.
The general procedure is in the post you linked to. Are you running into an issue? You may have to provide your entities so we can gain a better understanding.
--Sharon
Hi @etc6.
If you have found a solution to your question, please post a new reply with details of the solution and mark it as the Accepted Solution. This will benefit others on the community with the same question.
--Sharon
