I tried to create Postgres persistent provider to store stream and value stream data.
I am able to connect DB( checked using isConnected service) but not able to store and retrieve data, when I use the default service of add stream-entry I am not getting any errors. but I tried to access row count by calling GetStreamEntryCount then I got the error below-mentioned error message.
I am getting errors like this :
Unable to Invoke Service GetStreamEntryCount on Demo.Manual.STREAM : com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
You can refer to the article CS262935 (https://www.ptc.com/en/support/article/CS262935) to setup 2nd persistence provider.
The key steps are:
1> Create a DB User and grant the permission
2> Create a new Database
3> Grant enough permission for the new User to access to the database
4> Create Thingworx DB schema
5> In Thingworx Composer, Create a 2nd Persistence Provider and Configure the connection
Hi @sabharees ,
This issue seems similar resolved in the given article.
Kindly check and revert back the results Similar case .
Regards
Bhawna
Hi @bchaudhary ,
Thanks for the link. But still, I am not able to resolve these issues.
Also in my application log, I found this error log: Transaction has been marked as a failure for request /Thingworx/Things/Test.PP.Stream/Services/QueryStreamEntriesWithData.
Sab.
@sabharees , you can find the Application log, Database log, Error log under <ThingworxStorage>/logs . It will be helpful if you can upload these log files here
From the error log, you can see it reports that the table "stream" does not exist and function "upsert_stream_entry" doesn't exist, see the below error. You can check your Database and see if the table "stream" and function "upsert_stream_entry" exist or not. If there are there, does the DB user has enough permission to access to the database and schema?
[Error occurred while accessing the data provider.] org.postgresql.util.PSQLException: ERROR: relation "stream" does not exist
Batch entry 0 select * from upsert_stream_entry('Test.Stream.PP_Test','sravi','2021-08-25 18:30:00+00','{"meterName":"tedt","meterValue":1231.0,"timestamp":1629972000000}','0.0,0.0,0.0','User','[]') as result was aborted: ERROR: function upsert_stream_entry(character varying, character varying, unknown, jsonb, character varying, character varying, jsonb) does not exist
Hint: No function matches the given name and argument types. You might need to add explicit type casts.
Position: 15 Call getNextException to see other errors in the batch.
The key steps are:
1. Using the newly created DB user to login to the newly Database schema, and see if the table "stream" and function "upsert_stream_entry" exist or not in the Database.
2. If there are there, export your Persistence Provider and upload it here
Issue has been found and resolved. It was from postgres DB side.
Thanks for the help !!
Sab.
