Postgres Persistence provider [Data store unknown error]
sabharees
I tried to create Postgres persistent provider to store stream and value stream data.
I am able to connect DB( checked using isConnected service) but not able to store and retrieve data, when I use the default service of add stream-entry I am not getting any errors. but I tried to access row count by calling GetStreamEntryCount then I got the error below-mentioned error message.
I am getting errors like this :
Unable to Invoke Service GetStreamEntryCount on Demo.Manual.STREAM : com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
1 ACCEPTED SOLUTION
Jimwang
(To:Jimwang)
@sabharees ,
You can refer to the article CS262935 (https://www.ptc.com/en/support/article/CS262935) to setup 2nd persistence provider.
The key steps are:
1> Create a DB User and grant the permission
2> Create a new Database
3> Grant enough permission for the new User to access to the database
4> Create Thingworx DB schema
5> In Thingworx Composer, Create a 2nd Persistence Provider and Configure the connection
10 REPLIES 10
Hi @sabharees ,
This issue seems similar resolved in the given article.
Kindly check and revert back the results Similar case .
Regards
Bhawna
sabharees
(To:bchaudhary)
Hi @bchaudhary ,
Thanks for the link. But still, I am not able to resolve these issues.
Also in my application log, I found this error log: Transaction has been marked as a failure for request /Thingworx/Things/Test.PP.Stream/Services/QueryStreamEntriesWithData.
Sab.
Hi @sabharees ,
Can you please attach the application logs?
Regards
Bhawna
sabharees
(To:bchaudhary)
Jimwang
(To:sabharees)
@sabharees , you can find the Application log, Database log, Error log under <ThingworxStorage>/logs . It will be helpful if you can upload these log files here
sabharees
(To:Jimwang)
Hi @Jimwang & @bchaudhary,
Attached logs.
Jimwang
(To:sabharees)
@sabharees ,
From the error log, you can see it reports that the table "stream" does not exist and function "upsert_stream_entry" doesn't exist, see the below error. You can check your Database and see if the table "stream" and function "upsert_stream_entry" exist or not. If there are there, does the DB user has enough permission to access to the database and schema?
[Error occurred while accessing the data provider.] org.postgresql.util.PSQLException: ERROR: relation "stream" does not exist
Batch entry 0 select * from upsert_stream_entry('Test.Stream.PP_Test','sravi','2021-08-25 18:30:00+00','{"meterName":"tedt","meterValue":1231.0,"timestamp":1629972000000}','0.0,0.0,0.0','User','[]') as result was aborted: ERROR: function upsert_stream_entry(character varying, character varying, unknown, jsonb, character varying, character varying, jsonb) does not exist
Hint: No function matches the given name and argument types. You might need to add explicit type casts.
Position: 15 Call getNextException to see other errors in the batch.
Jimwang
(To:Jimwang)
@sabharees ,
The key steps are:
Jimwang
(To:Jimwang)
@sabharees
1. Using the newly created DB user to login to the newly Database schema, and see if the table "stream" and function "upsert_stream_entry" exist or not in the Database.
2. If there are there, export your Persistence Provider and upload it here
sabharees
(To:Jimwang)
@Jimwang,
Issue has been found and resolved. It was from postgres DB side.
Thanks for the help !!
Sab.
