Problem while importing 3D Model Viewer extension
tcoufal
Hi I am on TW 7.2.5
I am trying to import 3D model viewer extension. This is what I get:
Application log:
Anyone has the same issue.
I've checked the content of that extension and jszip.min.js is there (i am not sure about slash,backslash though)
ttielebein
(To:tcoufal)
Can you try opening the metadata.xml file and seeing if you can swap those slashes to backslashes? If the file is indeed located in the libs/ folder, then I can't imagine what else the issue could be.
