Purge ALL datatable entries within a time range
ague
How do I purge any and all entries for a given datatable that are within a certain time range? I don't care what values may be contained within the time range - I will want to delete them, regardless.
I've tried these two out-of-the-box methods from PTC:
Things["MyDataTable"].PurgePropertyHistory({
propertyName: undefined,
endDate: myEndTimeStamp,
immediate: true,
startDate: myStartTimeStamp
...and......
Things["Ford.PFS.GM.Historian.Repository"].PurgeSelectedPropertyHistory({
propertiesToPurge: eventFramesInfoTable
/* I passed an empty infotable here that was the same shape as my data table */,
endDate:myEndTimeStamp,
startDate:myStartTimeStamp
8 REPLIES 8
PaiChung
22-Sapphire I
(To:ague)
I believe that service is not a DataTable service but applies to ValueStreams
You can use: DeleteDataTableEntriesWithQuery
ague
(To:PaiChung)
Those two services that I copied in my question are datatable services - I found them as out-of-the-box services associated with my datatable.
I'll try the query method you suggested and post the results here.
Thank you!
PaiChung
22-Sapphire I
(To:ague)
Just to clarify, all Things will have the ValueStream services like:
QueryPropertyHistory, QueryNumberPropertyHistory etc.
Those two you were trying to use, I'm fairly certain are part of that set.
If you look at the DataTable ThingTemplate, I believe they aren't part of that set of services.
Confusing I know!
ague
(To:PaiChung)
So then I will assume that this screen shot, attached, is a bug, which PTC will fix.
(blacked-out content is my datatable name)
Constantine
(To:ague)
It's not a bug -- you can put some logged properties on a data table, associate a value stream with it, and query / purge those properties via those services. They have nothing to do with the content of that data table though.
Constantine
ague
(To:Constantine)
Very confusing - seems like not everyone is singing from the same song sheet. Oh well, it's not important - moving on.
Can someone please reply to my earlier post (above this one)? Pai seemed to cite a method which does not exist on data tables. What other method should I be looking for?
My original question: is there a way to purge any and all data table entries by time period, regardless of the content stored inside them?
Constantine
(To:ague)
Regarding your original question, you should follow @PaiChung advise and use the service DeleteDataTableEntriesWithQuery, which is defined on DataTables.
ague
(To:ague)
There seems to be no such service as you are referring to. I've taken a screen shot of what is available (attached).
** I also triple-checked that the entity in question is instantiating the 'DataTable' thing.
