Purge ALL datatable entries within a time range
  • September 25, 2019
  • 4312 views
How do I purge any and all entries for a given datatable that are within a certain time range? I don't care what values may be contained within the time range - I will want to delete them, regardless.
I've tried these two out-of-the-box methods from PTC:
Things["MyDataTable"].PurgePropertyHistory({
propertyName: undefined,
endDate: myEndTimeStamp,
immediate: true,
startDate: myStartTimeStamp
...and......
Things["Ford.PFS.GM.Historian.Repository"].PurgeSelectedPropertyHistory({
propertiesToPurge: eventFramesInfoTable
/* I passed an empty infotable here that was the same shape as my data table */,
endDate:myEndTimeStamp,
startDate:myStartTimeStamp
22-Sapphire I
September 26, 2019
I believe that service is not a DataTable service but applies to ValueStreams
You can use: DeleteDataTableEntriesWithQuery
ague1-VisitorAuthor
Those two services that I copied in my question are datatable services - I found them as out-of-the-box services associated with my datatable.
I'll try the query method you suggested and post the results here.
Thank you!
ague1-VisitorAuthor
So then I will assume that this screen shot, attached, is a bug, which PTC will fix.
(blacked-out content is my datatable name)
