Raspberry Pi Property Updating Problem, Code 202 could not set properties on server
darvasr
3-Newcomer
Hi!
I did set up the environment as the tutorial suggested, but when I start the luaScript, the following debug message that I get (see pic below). I tried to attach the http server to different port, recreated the thing entity, but seems the properties dont get updated, however if i readd the bindings they get refreshed. What could be the problem, if there is any?
slangley
(To:darvasr)
Hi @darvasr.
From our testing, we were able to create the same error message when a thing doesn't exist.  The unbound monitor should show these failures.
If you still have issues, please let us know.
--Sharon
slangley
(To:darvasr)
Hi @darvasr.
--Sharon
slangley
(To:darvasr)
Hi @RD_10005577.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
