Hi!
I did set up the environment as the tutorial suggested, but when I start the luaScript, the following debug message that I get (see pic below). I tried to attach the http server to different port, recreated the thing entity, but seems the properties dont get updated, however if i readd the bindings they get refreshed. What could be the problem, if there is any?
Hi @darvasr.
From our testing, we were able to create the same error message when a thing doesn't exist. The unbound monitor should show these failures.
If you still have issues, please let us know.
--Sharon
Hi @darvasr.
--Sharon
Hi @RD_10005577.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
