Regarding CSV files processing.
Bhanu_Manoj
9-Granite
Hi team,
I have a CSV file in thingworx SystemRepository. I am able to read the contents in the file using Resources["CSVParserFunctions"].ReadCSVFile(params). Is there any service that can give me the File Size and Last Modified Date of the file?
I have seen a service GetLastModifiedDate() but it is not useful.
Thanks and regards,
Hi @Bhanu_Manoj,
There is also the service GetFileListing which executes without needing to specify a path, it will show the files from your repository with Last Modified Date and size.
Hope it helps,
4 REPLIES 4
Hello @Bhanu_Manoj ,
Have you tried to execute the service GetFileListingsWithLinks, it should show the File Size and Last Modified Date of the file.
Hope it helps,
Hi @Ciprian-Traian,
Can you kindly let me know from where i have to use the service GetFileListingsWithLinks. I couldn't see it in CSVParserFunctions.
My file is present in a path in SystemRepository. i am trying to use the service in composer.
Thanks and Regards
Hello @Bhanu_Manoj,
You would need to create a File Repository Thing, then use the GetFileListingWithLinks to access the path where your file is present in the SystemRepository.
Hope it helps,
Hi @Bhanu_Manoj,
Hope it helps,
