Regarding Custom Authenticator
tayyasamy
1-Newbie
I want to get temporary application key generated for each user authenticates in custom authenticator. Because, i want to connect to thingworx using node js with rest calls.
3 REPLIES 3
PaiChung
22-Sapphire I
(To:tayyasamy)
What is the reason why this needs to be a temporary key?
Hi Pai Chung,
I have a different requirement for doing SSO with Thingworx and Active Directory.
My requirement is,
I have two instances of thingworx and mode of communication to thingworx is through rest calls through node js and active directory is configured.
I am giving my requirement in points.
1. I need to get username and password from Node JS Login Custom HTML Page.
2. Then, i need to send username and password to some authenticators, which should authenticate my username and it has to come back as response.
(Here, i tried creating custom authenticator and getting validated user, but in response i could not what to send whether sessionid, applicationkey for currently authenticated user, or success message).
3. After getting response, i need to make calls to thingworx from node js until user clicks Logout button in my nodejs application.
4. If user clicks on logout button, i need to logout my session in active directory and in thingworx as well, if some session is maintained there.
I found some docs in support.ptc.com and i am trying to understand but i need so much clarifications on whether i am doing correct.
My clarifications are,
1. Whether my approach is correct, if i thingworx custom authenticator to authenticate and logout sessions of active directory.
2. If you accept first point, then i know how to send authenticate request to custom authenticator, but i does not know how to send logout url request.
PaiChung
22-Sapphire I
(To:tayyasamy)
If you are doing Active Directory you can use the Active Directory entity to define the Active directory you need to auth against right within Thingworx
http://thingworx.ptc.com/help/thingworx_hc/thingworx_7_hc/ThingWorx_Core/ThingWorxHelpCenterDITAFiles/Security/DirectoryServicesAuthentication/DirectoryServicesExample.html#
