Jan 2, 2017 2:22 PM UTC
Import of GoogleWidgets_ExtensionPackage.zip -> Extension must have a metadata.xml file
HI,
For showing the google maps in the mashups i tried putting my google maps API key in the extension downloaded from thingworx marketplace . I edited the metadata.xml with api key and rezipped, but while trying to import/upload it in Thingworx composer. It shows "Extension must have a metadata.xml file" , actually it has the metadata.xml . Please provide a solution for me.
ds-21Answer
Jan 3, 2017 7:04 AM UTC
Hi Bharath Kumar,
             I think extension folder structure is problem. you can check the zip file once, double clicking the zip folder check whether metadata file is present or not. because some time zip folder contain another folder, that folder contain the metadata file may be..
Dinesh
ds-211-VisitorAnswer
Hi Bharath Kumar,
Dinesh
bkumar-311-VisitorAuthor
Jan 3, 2017 7:10 AM UTC
Thanks for the reply.
Tried unzipping the file this is my file structure,
looks correct for me. First is the zip file . Next folder is the unzipped one, containing metadata.xml file & ui folder.
Any other thoughts?
Jan 4, 2017 5:31 AM UTC
Hi Bharath Kumar,
           it correct structure now you select (the metadata file,ui folder), then you converted into zip file format. it may be working fine
Dinesh
Jan 3, 2017 10:27 AM UTC
Hi Bharath Kumar​,
There could be two reasons:
1. The zip file you have is zipped twice. In this case you need to unzip the outer zip file to get the inner zip file.
2. As Dinesh mentioned there could be folder inside folder which contains the metadata.xml file. In this case extract the folder and then zip the inner folder and import this in ThingWorx.
In short the metadata file should be available in the first folder for the Extension import to work successfully.
I hope it helps.
Ankit Gupta
Jan 3, 2017 12:12 PM UTC
Bharath Kumar​,
Unzip your folder and zip TW_Download_Google_Map and import the new zip file.
Ankit Gupta
20-Turquoise
Jan 5, 2017 8:44 PM UTC
I see you downloaded the extenison from the marketplace. What is your Thingworx platform version? I will test locally to see if the extension provided on the marketplace needs to be corrected.
Jan 6, 2017 7:05 AM UTC
Issue is sorted out. Extension is proper!!!
Cool. Thanks for the reply
