The message you are trying to access is permanently deleted.
Even Though I have 20 Entries in the Database, the Repeater and Collection widget is showing only last added Data in all the Cells as shown below:
The Only Binding I have given to them is GetDataTableEntries .....!
Hi @SP_9715784,
As suggested in https://community.ptc.com/t5/ThingWorx-Developers/Collection-Widget-data-is-repeated-in-all-Cells/td-p/710387 have you defined the MashupGlobalPropertyBinding parameter of the Collection widget ?
There is a tutorial on how to use the Collection widget here : Organize Your UI with the Collection Widget. It will teach you step by step what are the requirements for your Collection widget to display the data from your infotable and I believe might help you with your use case.
Let us know if this helps !
Hi @SP_9715784,
Hi @SP_9715784.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
