Reset Password Button
pbaierl
I just added the password reset button on the organization login.  I verified that my email server works correctly on it's own.  However, when pressing the reset password button I get the message:
Internal Error - unable to send email
Any thoughts on what I could be missing?  I made sure that the user name, first name, last name, and email address are being entered correctly.
Paul
7 REPLIES 7
ttielebein
(To:pbaierl)
Is that error appearing on the mashup? Can you see if there are any more detailed errors in the logs?
pbaierl
(To:pbaierl)
Here is what I was able to find after a lot a digging.   It looks as though it's failing to confirm the credentials.
I did double check I was entering the information correctly.  I actually copied/pasted values into to box.
pbaierl
(To:pbaierl)
I found the following when checking the security logs:
ttielebein
(To:pbaierl)
This seems to be somewhat complicated. You may want to open a support case for this
pbaierl
(To:pbaierl)
ok thanks Tori
posipova
20-Turquoise
(To:pbaierl)
The error “Unable to Send Message: 501 5.1.8 Bad address syntax” points at
https://www.howtoforge.com/community/threads/smtp-server-response-bad-recipient-address-syntax-state-14.34405/
On the mail server end, all incoming messages need to be enabled.
Thanks for your help Polina.  I will have this looked on our mail server.
