Rest API Service problem from javascript
Highlighted
Visitor
I'm trying to create a function call to a service with javascript.
This is my code:
var data = "{\n\t\"input\":{\n\t\t\"space\": \"Hki Pa A 109\",\n\t\t\"type\": \"TEMP\"\n\t}\t\n}";
var xhr = new XMLHttpRequest();
xhr.withCredentials = true;
xhr.addEventListener("readystatechange", function () {
  if (this.readyState === 4) {
console.log(this.responseText);
xhr.open("POST", "https://server-address/Thingworx/Things/PWIMAPI/Services/GetMeasurementPoints");
xhr.setRequestHeader("accept", "application/json");
xhr.setRequestHeader("content-type", "application/json");
xhr.setRequestHeader("appkey", "my-app-key");
xhr.setRequestHeader("cache-control", "no-cache");
xhr.send(data);
If I run this in postman it returns the correct json-content, but when I run it in a HTML-file on the server I get:
Status Code:
401 Unauthorized
Have anyone had a similar problem before? Any suggestion how to solve this?
11 REPLIES 11
Re: Rest API Service problem from javascript
How are you authenticating?
No extra authentication, just with the appkey.
Appkey in the url? Is it an 8.0 instance?
If so, https://community.thingworx.com/community/developers/blog/2017/06/08/new-technical-changes-in-thingw...
"The Allow Application Key as URL Parameter option can be enabled or disabled on the ThingWorx PlatformSubsystem’s configuration page, accessible at System > Subsystems > PlatformSubsystem > Configuration."
No it's not an 8.0 instance.
I haven't tried to pass it in the URL, I would rater pass it as it in the header. I mean it's working if I use the Postman plugin (in chrome). I also have it working from a Unity3D project, but when I add it as a javascript function that is run when a webpage loades then it won't authenticate.
If you open your browser developer tools, can you see any more detailed errors in the activity?
Failed to load "My Service URL": Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin "Webpage domain URL" is therefore not allowed access. The response had HTTP status code 401.
Am I missing some header tag on my webpage?
We have an Ionic App working, the only difference between our code and yours:
xhrfetchdata.open("POST", "url" ,true);
//setting up headers
xhrfetchdata.setRequestHeader("Content-Type", "application/json");
xhrfetchdata.setRequestHeader("Accept", "application/json");
xhrfetchdata.setRequestHeader("x-thingworx-session", "true");
xhrfetchdata.setRequestHeader("appKey", token);
Is your URL also a https or is it a http?
https of course.
