Rest API Service problem from javascript
3studio
3-Visitor
I'm trying to create a function call to a service with javascript.
This is my code:
var data = "{\n\t\"input\":{\n\t\t\"space\": \"Hki Pa A 109\",\n\t\t\"type\": \"TEMP\"\n\t}\t\n}";
var xhr = new XMLHttpRequest();
xhr.withCredentials = true;
xhr.addEventListener("readystatechange", function () {
  if (this.readyState === 4) {
console.log(this.responseText);
xhr.open("POST", "https://server-address/Thingworx/Things/PWIMAPI/Services/GetMeasurementPoints");
xhr.setRequestHeader("accept", "application/json");
xhr.setRequestHeader("content-type", "application/json");
xhr.setRequestHeader("appkey", "my-app-key");
xhr.setRequestHeader("cache-control", "no-cache");
xhr.send(data);
If I run this in postman it returns the correct json-content, but when I run it in a HTML-file on the server I get:
Status Code:
401 Unauthorized
Have anyone had a similar problem before? Any suggestion how to solve this?
11 REPLIES 11
posipova
20-Turquoise
(To:3studio)
How are you authenticating?
No extra authentication, just with the appkey.
posipova
20-Turquoise
(To:3studio)
Appkey in the url? Is it an 8.0 instance?
If so, https://community.thingworx.com/community/developers/blog/2017/06/08/new-technical-changes-in-thingworx-800#comment-3989
"The Allow Application Key as URL Parameter option can be enabled or disabled on the ThingWorx PlatformSubsystem’s configuration page, accessible at System > Subsystems > PlatformSubsystem > Configuration."
No it's not an 8.0 instance.
I haven't tried to pass it in the URL, I would rater pass it as it in the header. I mean it's working if I use the Postman plugin (in chrome). I also have it working from a Unity3D project, but when I add it as a javascript function that is run when a webpage loades then it won't authenticate.
posipova
20-Turquoise
(To:3studio)
If you open your browser developer tools, can you see any more detailed errors in the activity?
Failed to load "My Service URL": Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin "Webpage domain URL" is therefore not allowed access. The response had HTTP status code 401.
Am I missing some header tag on my webpage?
We have an Ionic App working, the only difference between our code and yours:
xhrfetchdata.open("POST", "url" ,true);
//setting up headers
xhrfetchdata.setRequestHeader("Content-Type", "application/json");
xhrfetchdata.setRequestHeader("Accept", "application/json");
xhrfetchdata.setRequestHeader("x-thingworx-session", "true");
xhrfetchdata.setRequestHeader("appKey", token);
Is your URL also a https or is it a http?
https of course.
pkg
(To:CarlesColl)
i am Also facing the similar error. please help..
Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'null' is therefore not allowed access. The response had HTTP status code 401.
My code
<!DOCTYPE html>
<html>
<body>
<h2>Calling ThingWorx Restful Api using XMLHttpRequest Object</h2>
<div id="demo">
<button type="button" onclick="loadXMLDoc()">Call Thingworx Restful Service</button>
</div>
<script>
function loadXMLDoc() {
var xmlhttp;
var Data = JSON.stringify({
"ExtendFlag": "173"
var url = "URL";
if (window.XMLHttpRequest) {
xmlhttp = new XMLHttpRequest();
//xmlhttp.setRequestHeader("Authorization","Basic "+btoa("Username"+":"+"Password"));
} else {
// code for older browsers
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("demo").innerHTML =
this.responseText;
xmlhttp.open("PUT", url, true);
xmlhttp.withCredentials = true;
xmlhttp.setRequestHeader("x-thingworx-session", "true");
xmlhttp.setRequestHeader("Access-Control-Allow-Credentials", "true");
xmlhttp.setRequestHeader("Access-Control-Allow-Methods", "GET");
xmlhttp.setRequestHeader("Access-Control-Expose-Headers","appkey, Content-Type");
xmlhttp.setRequestHeader("Access-Control-Allow-Origin", "*");
xmlhttp.setRequestHeader("appkey", "APPKEY");
xmlhttp.setRequestHeader("Content-type", "application/json");
xmlhttp.setRequestHeader("Accept", "application/json");
xmlhttp.setRequestHeader("cache-control", "no-cache");
xmlhttp.send(Data);
</script>
</body>
</html>
I am using this stand alone Page.
ThingWorx version - 7
Tomcat version - tomcat 8
@CarlesColl
Try, append method=POST in your URL.
POST - to execute/invoke tx services via url.
