I'm trying to create a function call to a service with javascript.
This is my code:
var data = "{\n\t\"input\":{\n\t\t\"space\": \"Hki Pa A 109\",\n\t\t\"type\": \"TEMP\"\n\t}\t\n}";
var xhr = new XMLHttpRequest();
xhr.withCredentials = true;
xhr.addEventListener("readystatechange", function () {
if (this.readyState === 4) {
console.log(this.responseText);
xhr.open("POST", "https://server-address/Thingworx/Things/PWIMAPI/Services/GetMeasurementPoints");
xhr.setRequestHeader("accept", "application/json");
xhr.setRequestHeader("content-type", "application/json");
xhr.setRequestHeader("appkey", "my-app-key");
xhr.setRequestHeader("cache-control", "no-cache");
xhr.send(data);
If I run this in postman it returns the correct json-content, but when I run it in a HTML-file on the server I get:
Status Code:
401 Unauthorized
Have anyone had a similar problem before? Any suggestion how to solve this?
How are you authenticating?
No extra authentication, just with the appkey.
Appkey in the url? Is it an 8.0 instance?
"The Allow Application Key as URL Parameter option can be enabled or disabled on the ThingWorx PlatformSubsystem’s configuration page, accessible at System > Subsystems > PlatformSubsystem > Configuration."
No it's not an 8.0 instance.
I haven't tried to pass it in the URL, I would rater pass it as it in the header. I mean it's working if I use the Postman plugin (in chrome). I also have it working from a Unity3D project, but when I add it as a javascript function that is run when a webpage loades then it won't authenticate.
If you open your browser developer tools, can you see any more detailed errors in the activity?
Failed to load "My Service URL": Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin "Webpage domain URL" is therefore not allowed access. The response had HTTP status code 401.
Am I missing some header tag on my webpage?
We have an Ionic App working, the only difference between our code and yours:
xhrfetchdata.open("POST", "url" ,true);
//setting up headers
xhrfetchdata.setRequestHeader("Content-Type", "application/json");
xhrfetchdata.setRequestHeader("Accept", "application/json");
xhrfetchdata.setRequestHeader("x-thingworx-session", "true");
xhrfetchdata.setRequestHeader("appKey", token);
Is your URL also a https or is it a http?
https of course.
i am Also facing the similar error. please help..
Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'null' is therefore not allowed access. The response had HTTP status code 401.
My code
<!DOCTYPE html>
<html>
<body>
<h2>Calling ThingWorx Restful Api using XMLHttpRequest Object</h2>
<div id="demo">
<button type="button" onclick="loadXMLDoc()">Call Thingworx Restful Service</button>
</div>
<script>
function loadXMLDoc() {
var xmlhttp;
var Data = JSON.stringify({
"ExtendFlag": "173"
var url = "URL";
if (window.XMLHttpRequest) {
xmlhttp = new XMLHttpRequest();
//xmlhttp.setRequestHeader("Authorization","Basic "+btoa("Username"+":"+"Password"));
} else {
// code for older browsers
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("demo").innerHTML =
this.responseText;
xmlhttp.open("PUT", url, true);
xmlhttp.withCredentials = true;
xmlhttp.setRequestHeader("x-thingworx-session", "true");
xmlhttp.setRequestHeader("Access-Control-Allow-Credentials", "true");
xmlhttp.setRequestHeader("Access-Control-Allow-Methods", "GET");
xmlhttp.setRequestHeader("Access-Control-Expose-Headers","appkey, Content-Type");
xmlhttp.setRequestHeader("Access-Control-Allow-Origin", "*");
xmlhttp.setRequestHeader("appkey", "APPKEY");
xmlhttp.setRequestHeader("Content-type", "application/json");
xmlhttp.setRequestHeader("Accept", "application/json");
xmlhttp.setRequestHeader("cache-control", "no-cache");
xmlhttp.send(Data);
</script>
</body>
</html>
I am using this stand alone Page.
ThingWorx version - 7
Tomcat version - tomcat 8
Try, append method=POST in your URL.
POST - to execute/invoke tx services via url.
