Retrieve multiple email addresses from data table and insert as input into email service
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I have a service where I retrieve one to many email addresses from my data table based on certain inputs. How do insert these into the send message service? It currently gives me the following error,
"javascript service. Message ::Invalid or malformed email address entered."
- Labels:
Coding
Design
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I'm not so clear what you want to do as the code you provided seems to be missing some comments and brackets.
But creating a string like "email1;email2;email3;" for the SendMessage service you can just do
var tableLength = result.rows.length;
var emailReceivers = ""; // empty mail string
for (var x = 0; x < tableLength; x++) {
var row = result.rows[x];
emailReceivers += row.Email + ";"; // append "email;" to receivers
if (emailReceivers.length > 0)
emailReceivers = emailReceivers.slice(0, -1); // remove last ;
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Article - "How to send an email to multiple recipients via ThingWorx Mail Extension": https://www.ptc.com/en/support/article/cs310001
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
can you share some code so we can help with it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Bits and pieces of this service work. The first service to return the email address based on the inputs works, but it retrieves them as an infotable. Everything else in between works to find failures and create the email works. It just wont send my email since i'm not putting in the emails from the first service correctly. Hardcoding the emails into the address input will work as well but I need to select the emails based on area and shift.
//First gather email list based on area and shift of the audit
// result: INFOTABLE dataShape: "AuditEmailList.DS"
var EmailList = Things["AuditEmailList.DT"].GetEmailList({
Shift: Shift /* INTEGER */,
Area: Area /* STRING */
var params = {
t:EmailList /* INFOTABLE */,
columns: "Email" /* STRING */
var result = Resources["InfoTableFunctions"].Distinct(params);
for (var x=0; x < tableLength; x++) {
//First check for and get failure information by AuditID
var failureinfo = Things["MSSQLConnector.AuditForms"].GetFailInfoPieceCheck({
AuditID: AuditID /* INTEGER */
var params = {
t:failureinfo /* INFOTABLE */,
columns: "UserID,TOE,Shift,LineID,Item,PassFailNa,Notes" /* STRING */
//Second, if failures exist send one email with all the failure info from infotable above.
result: INFOTABLE
var emailContent="<html><body><table>";
Add heading row (column names)
emailContent = emailContent + "<tr><th>UserID</th><th>TOE</th><th>Shift</th><th>LineID</th><th>Item</th>";
emailContent = emailContent + "<th>PassFailNa</th><th>Notes</th>";
emailContent = emailContent + "</tr>"; // End heading row
if (tableLength > 0) {
var row = result.rows[x]; // Get Row Data
emailContent =emailContent +"<tr><td>"+row.UserID+"</td><td>"+row.TOE+"</td><td>"+row.Shift+"</td>";
emailContent =emailContent + "<td>"+row.LineID+"</td><td>"+row.Item+"</td><td>"+row.PassFailNa+"</td>";
emailContent =emailContent + "<td>"+row.Notes+"</td>";
// Add closing tag to row.
emailContent =emailContent + "</tr>";
} // Next Row
emailContent = emailContent + "</table></body></html>"; // Add Closing HTML tags to body content.
Things["MailServer"].SendMessage({
cc: undefined /* STRING */,
bcc: undefined /* STRING */,
subject: "Piece Check Audit Failure" /* STRING */,
to: EmailList,
body: emailContent /* HTML */
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ok so thanks again for the solution! It does work by pulling up the correct emails from my table and converts them to a string separated by ;. Just two side notes. One, everything does work and goes through, however I get the following error in the application log
"class com.thingworx.dsl.engine.adapters.ThingworxInfoTableAdapter cannot be cast to class com.thingworx.types.InfoTable (com.thingworx.dsl.engine.adapters.ThingworxInfoTableAdapter and com.thingworx.types.InfoTable are in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @6de54b40)"
Two, the slice removed all ;'s out of the result. I commented it out of the service and just left last one and email still send so no big deal. Thanks again for your help, I really appreciate it.
