Running validator after textbox input
ague
I have a textbox, and the text is bound to a validator widget. The validator widget checks to make sure that the input is not null/empty, and if not, it runs a service. Everything works as expected, but the validator only runs when the user clicks off the textbox (I have no enter/submit button).
I want to rework this so that the validator runs without the user clicking off - or, make this automatic some how.
Any thoughts?
Constantine
(To:ague)
There it is from the DataWedge spec, by the way:
8 REPLIES 8
zyuan1
18-Opal
(To:ague)
I think the textbox is working as expected, you need to click out, or press the Enter/Tab in the keyboard to finish the string input.
ague
(To:zyuan1)
Yes, as per my original post, I confirmed that the text box is working as expected when I click off it. I'm just wondering if there's a way to do this without clicking off it.
The background of my request is this - I'm building an application that scans a QR code. I can scan the code, and put it in a text box successfully. But then the user is forced to click somewhere else on the page in order to be able to do anything further. I want the application to work automatically just when the user scans, without artificially forcing him to click somewhere else just to get the services to run.
zyuan1
18-Opal
(To:ague)
You can bind it to both a Label widget and a textbox widget, and use Events Router widget to bind to the final result.
The Label helps you get the result without clicking outside, the textbox widget allows you to still make modifications to the string, and events router helps you get both the results
Constantine
(To:ague)
What do you use for scanning QR codes? If that's some hardware solution simulating keystrokes, it might be able to simulate pressing <ENTER> at the end of the scan, which will effectively "click out" of the text box.
/ Constantine
ague
(To:Constantine)
That's a great point - I'll look into that!
I'm working with a Zebra Scanner and I'm using DataWedge to read/scan both QR and traditional bar codes.
Constantine
(To:ague)
Just thought about it... there's another nice side-effect if you manage to make <ENTER> work -- the text field doesn't lose focus in this case. You'll just need to call its ResetToDefaultValue when you're done processing to allow serial scanning of QR codes. Of course that won't help if the user actually clicks out of the textbox, but that's also something you can avoid by resizing your textbox to cover entire mashup. I know that sounds and looks even more weird, but it may be a quick and practical workaround.
Constantine
(To:ague)
ague
(To:Constantine)
Thank you, @Constantine! This ended up working for me!
