The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Selected Analytics Gateway is not connected.
MinNan
11-Garnet
hello
i work on I work on a local instance of ThingWorx 8.2 with ATE.
days before, i couldn't load the dataset,and i find it the reason was "Selected Analytics Gateway is not connected" in the setting.
i tried to reinstall ATE but it didn't work.and i have referred the article "https://community.ptc.com/t5/ThingWorx-Developers/Selected-Analytics-Gateway-is-not-connected/m-p/511980" and follow its step, but it is still not sloved.
what else can i do to solve the problem?
Thanks in advance.
Minnan
9 REPLIES 9
cmorfin
(To:MinNan)
Hi MinNan
You mentioned using a local instance of ThingWorx 8.2 with ATE.
Could you please clarify how did you install this local instance of ThingWorx ?
Could you also send:
- the output of the command docker ps -a
- the edge.log file created after executing the command docker logs edgems > edge.log
Thank you
kind regards
Christophe
MinNan
11-Garnet
(To:cmorfin)
hi Christophe
i am working on win10, and i install the ATE with the docker running.and i use AnalyticsTrialEdition-8.2.0-r3-windows-installer.
tell me if you need more details of that.
here is the ouput of the command docker ps -a
and the file is in the attachment
cmorfin
(To:MinNan)
Hi MinNan
Ok so the docker ps -a shows that most of your contianer are ina Exited states, which means they are not running.
Among them is the edgems, thereofre this is why the gateway is not connected.
You will want to:
1) Ensure you have allocated enough Memory to the docker process:
For Docker for Windows , select docker Settings > Advanced > Memory and set at least 5 or 6 Gb
2) Stop the ThingWorx Analytics Trial Edition
3) check with docker ps, that no containers are running or starting
4) start ThingWorx Analytics Trial Edition
5) check with docker ps -a that no containers are in Exited status
Then access Builder
Hope this helps
Christophe
MinNan
11-Garnet
(To:cmorfin)
hi Christophe
i have allocated memory of 6G to docker process.
i found taht there still some containers are running after the ATE stop.
and some containers are at the exited stuas after i start the ATE again.
Please help
Kind regards
Minnan
MinNan
11-Garnet
(To:cmorfin)
hi christophe
i have allocated 6G memory to docker process.
and i found some containers are still running when i stop the ATE.
after starting ATE again, some containers are at the exited staus.
Please help
Kind regards
Minnan
cmorfin
(To:MinNan)
Hi Minnan
Could you please upload :
- All the installation log files found in the <ThingWorxAnalyticsTrialEdition> folder
- a zip of %USERPROFILE%/twx-analytics folder excluding the db subfolder.
Thank you
Kind rgeards
Christophe
CCi_9
11-Garnet
(To:cmorfin)
Hi
I have the same situation as him
This is the zip
thank you
Kind rgeards
CCi_9
cmorfin
(To:CCi_9)
Hi CCI_9
I don't think this is the same issue. The logs files you provided do not point to exited containers.
I think it is best you open a new thread with your exact situation so we can address it in its own way.
Christophe
CCi_9
11-Garnet
(To:cmorfin)
Hello
I have opened a new thread, please have a look.
CCI_9
