I have a trial version Thingworx of 3 months installed on my computer. I downloaded and installed Httper APP on my smartphone and I´m trying to send information to thingworx via REST API but I can´t connect to Thingworx and the error message is: "Cannot access to the URL, check your connection and service provider"
I have connected smartphone and computer in the same network.
IP Computer= 192.168.1.22
IP Smartphone= 192.168.1.24
Port= 8080
This is the URL, headers and body:
Request method PUT
URL= http://192.168.1.22:8080/Thingworx/Things/DataLogger/Properties/Temperatura
Headers= AppKey= b2245650-d77e-4f8a-8dbb-4acbabf85230
Content-Type => application/json
Accept =>application/json
Body= {
"Temperatura": 34
Do I have something wrong? Could you help me with that?
Thank you in advance
BR
Luis
Yes! Before doing REST API you need to ensure that Composer is accessible from your mobile browser.
Within the mobile browser can you get to Thingworx? Like <Thingworx Server>/Thingworx/Things/Datalogger/Properties
Then you need to check your computer's firewall settings -- looks like it doesn't allow incoming requests on port 8080.
/ Constantine
I have opened port 8080 in my computer´s firewall settings but it still doesn´t work. Is it possible that my antivirus is blocking my conexion?
Thank you
-Luis
