Hi All,
I'm trying to fire an event when a session variable is changed, but nothing seems to happen. I set up the variable and bound the changed event to a service, but when I update the session variable via a service, nothing happens. I did confirm that the variable is being updated. I'm using 8.5.3 and I found this:
Which is the same issue I appear to be having. I was just wondering if anyone else has noticed the same issue -- as I'm probably doing something wrong.
I'm trying to implement:
Option 1
Thanks!
This has somewhat been solved. I talked to a smart colleague who pointed me in a different direction. He suggested setting the variable via a mashup function and that seemed to do the trick!
Never could get the PTC example to work though.
Hi @jimh.
Glad you found a solution. I will have someone look at the articles you referenced for needed updates. They are both fairly old.
--Sharon
Hi @jimh.
One other thing, could you please mark your post containing the solution as the Accepted Solution for the benefit of others with the same question?
--Sharon
Hi @slangley
There isn't a post as we chatted on the phone. But, the gist of it is:
Instead of updating the session variable through the service, updated it through the actual mashup using a function. So when I want to update the contained mashup, I also fire the mashup function that sends its output to the session variable via the function -- if that makes sense.
Hi @jimh.
I have marked one of your posts as the solution. If you disagree with my choice, please let me know.
--Sharon
