Sorting an infotable in ascending order
kahmeng96
Hi all, I am trying to sort an infotable in ascending order of a column, in this case the LegReaction column.
As shown in the infotable above, I want to put the value of LegReaction (45) between values 40 and 50 without manually modifying the infotable but by JavaScript programming. Any help is greatly appreciated!
kahmeng96
(To:kahmeng96)
Hi all, I have found the solution by tinkering with the sort function
data.sort(function(a, b){return a.LegReaction-b.LegReaction});
You should follow algorithm to insert object in a sorted array: https://www.geeksforgeeks.org/search-insert-and-delete-in-a-sorted-array/
Sorry, I don't have the code but this is the idea, implement the inserting operation in infotable via a service following the above algorithm.
Workaround: add a row in infotable, doesn't matter the position and then use the Sort function:
Resources["InfoTableFunctions"].Sort(params)
Hope it helps,
Raluca Edu
kahmeng96
(To:raluca_edu)
Thanks for the advice, @raluca_edu! However, I found an easier solution which is the I accepted as the solution to my question.
You welcome! I saw your post after. Good luck!
kahmeng96
(To:kahmeng96)
Hi kahmeng96,
I know you already have a solution, but this might be an alternative...
//The code below sorts an infotable by the specified column.
var result = Resources["InfoTableFunctions"].Sort( {
     sortColumn: "LegReaction", t: myInfoTable, ascending: true
