Hi all,
I have two types of markers in Google Map Widget that represent two different values of a property (State-based formatting).
The problem is for the selected marker, I have no idea how to set two different types of this.
Any help?
Hi @PB_9026895,
Thanks for reaching out to PTC.
Take an example, suppose you already have created a state(named speedingState) with two different states, one is “Not Speeding", the other is "Speeding". And also you have associated different styling with "Not Speeding" and "Speeding" states in the definition of the state. Then you can follow below steps:
Best Regards,
/Yoyo
Hi yhan,
thank you for your reply.
The solution is clear, but I have some problems with the selected marker.
I want to set different types of selected markers. Is this possible to do in state-based formatting?
Thank you
Hi @PB_9026895,
I'm wondering if you would like to fulfill the below scenario?
If not, could you take an example to explain it?
/Yoyo
