Style Themes are not working
pshashipreetham
I am using Style Theme for around 50 Mashups, but suddenly labels, font weight and family are not working.
When I open the Mashup in the runtime, in the console, I see the below errors:
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
6 REPLIES 6
wcui
(To:pshashipreetham)
@pshashipreetham can you share your Mashup xml file and tell the version of your thingworx instance?
Hi @wcui ,
Thanks for the response. Mashup.xml will have a lot of dependencies, so it can't be shared.
Thingworx Version: 9.3.0
Shashi Preetham,
wcui
Sorry I wrongly clicked the "Accept as a Solution" button. Let's continue the investigation.
Did the issue suddenly happen? I mean is the style theme used to work normally? if yes, can you try a different browser or try clear cache?
besides, can you create a simple demo Mashup using the same style theme? if issue also reproduce there, please supply the demo entity and style theme.
Hi @wcui ,
So, the issue suddenly occurred, appearing in new mashups, too.
When I change the font-weight from Normal to Light, then Light to Normal, and Render on Runtime, I can see the Font weight as normal on the runtime.
I have checked in different browsers and incognito mode.
I will try to share the demo Mashup if possible.
Shashi Preetham,
wcui
@pshashipreetham Is it possible to share the demo mashup this week?
I think I need to open a Technical Case to do that.. due to confidentiality.
Shashi Preetham,
