ThingShape Mashup Example?
SOLVED
Highlighted
Newbie
I'm attempting to create a Mashup with Type ThingShape.  Is there an example or tutorial anywhere that is available on how to do this?
thanks in advance.
Tags (1)
1 ACCEPTED SOLUTION
Re: ThingShape Mashup Example?
For my experience, don't use it, will limit you on some unexpected ways, I it are there for historical purposes...
4 REPLIES 4
Highlighted
You can use a Standard Mashup to use with a ThingShape, Which it's the reason for what you want to use ThingShape type Mashup?
Highlighted
Trying to learn the platform and what I can do with it.  Since there is a ThingShape and ThingTemplate type of mashup, trying to use them.  If the answer is to always use the standard Mashup, just wondering what the ThingTemplate, and ThingShape types of Mashups are for then.
Highlighted
roger that, appreciate the honest feedback.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
