I am trying to set up the ThingWatcher on Ubuntu16. I keep getting the stage: "INITIALIZATION-FAILED".
I have tried the solutions on other similar topics but none of them work.
Hi
Seems your error is the one described at https://www.ptc.com/en/support/article?n=CS270006 .
You can possibly apply the resolution that match your version
Hope this helps
Kind regards
Christophe
I have some questions to help me better understand the issue:
John
1. My Thing watcher version is 2.0.5 for training server and 2.0.3 for result server.
2. I am using TWx 8.2.1-b140.
I am following the Thing watcher guide on the developer portal. I actually solved my original issue by deleting the "rampValue" attribute and recreate a new one. Now i get a new problem where the training end with a "FAILED" result with 2 error in the application log.
Bach
Hi Bach,
1 other question, does it ever reach any of the other phases while it is running, like monitoring or calibrating or does it just say initialization-failed?
John
I solved the Initialization-failed problem.
Now it goes through Initialized->Calibrating->Training->Failed
Bach
Hi
Hope this helps
Kind regards
Christophe
Thank you very much. It works now.
Changing the file path in the "microservices.properties" file fixed it.
On Ubuntu 16.04:
file.storage.path=file:///opt/ThingWatcher/files
Bach
