The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
ThingWorx 8.5 Installation Errors
RaulBernardo.PV
11-Garnet
errors when installing ThingWorx 8.5 How to fix
Translated by Community Moderator via Google Translate
erros ao instalar o ThingWorx 8.5 Como corrigir
Hi @RaulBernardo.PV.
The link for the manual installation instructions is included in my previous post.
--Sharon
6 REPLIES 6
What method are you using for installation?  Installer or Manual?  Have you reviewed the ThingWorx logs at \ThingworxStorage\logs or the Tomcat logs?  We need to see the errors.
--Sharon
these are from tom cat
estes são do tom cat
This log doesn't provide any useful information.  Did you use the installer or are you installing manually?  If installing manually, did you copy the Thingworx.war file to the <tomcat_home>\webapps folder?  Here are the instructions for the manual installation and these are the instructions if using the installer.
The logs we need are located at \ThingworxStorage\logs.  Please .zip them and attach to your reply.
--Sharon
What would it be to install manually?
O que seria instalar manualmente ?
--Sharon
