ThingWorx User authentication case sensitivity issue using Windchill Authentication
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
We are using Windchill Authentication for ThingWorx user authentication. Windchill can authenticate the AD users and doesn't validate case sensitivity, ThingWorx authentication fails for user when UserName is Upper/Lower Case . Example: if AD username is xyz.pqr, User can login and authenticate to Windchill with any username ( Xyz.Pqr/ xyz.pqr). However, in ThingWorx user can't get Authenticated with Xyz.Pqr
We've implemented SSO using Windchill 12.0.2 with TWX -9.3.
I know other enterprises using ThingWorx extensively with 1000s of concurrent users logging into system. Anyone can help? How to handle User Management in ThingWorx and Navigate?
- Labels:
Best Practices
Connectivity
Security
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello @vijayaRath,
The use case (enhancement request: "login username case-insensitive") mentioned in this post is currently not a part of the ThingWorx functionality. Also, this enhancement request is already in our (PTC) backlog.
This enhancement request could be considered in future releases of ThingWorx/Navigate; however, no timeline can be committed to at this time.
Abhi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Looks like your users will have to use the proper case.
For reference:
https://www.ptc.com/en/support/article/CS244222
https://www.ptc.com/en/support/article/CS259466
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Articles Suggest to Use PingFed with PTC Cloud . Are there any other Alternate approach ? We are not using PTC Cloud.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
That's why I said they have to use proper casing, I don't see another solution. The solution with PingFed is not tied to PTC Cloud, but I don't know details. Maybe create a ticket with support for that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello @vijayaRath,
Abhi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thank You Abhi for Notifying. We will require an workarouns untill we move to Fixed Build . Any ODea how Other CUstomer's are resolving this issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello @vijayaRath,
I have discussed this issue with our team, and unfortunately, currently we don't have a proper workaround for this issue.
For now, please try to use the exact username while logging into ThingWorx.
Abhi
