Thingworx 8.4 with postgre learning document
svisveswaraiya
Could any one please share the link to download the documents for learning and using ThingWorx 8.4 to work on widgets and extensions.
I couldn't find the document to use ThingWorx-Rockwell-FT-MES-8.4.1-00-extension. Where can I find the documents to use this extension or could any one provide the link to download this?
Thanks in advance,
Shalini V.
Hi @svisveswaraiya
The developer portal may have what you need.  Here are a couple of guides:
https://developer.thingworx.com/resources/guides/basic-mashup-widgets
https://developer.thingworx.com/resources/guides/data-widgets-and-building-experience
While on the developer portal, if you search for widget, you will find many other guides that may be helpful.
--Sharon
Hi @svisveswaraiya
This may provide some help.  If it fails to answer your questions, please provide more detail and I'll try to track down the answers.
--Sharon
Hi slangley ,
Thanks for your swift response. This article does not help me much.
I’m looking for some article where it explains how to use and what purpose it can be used?
Please help me with the link if its available for this use case.
Shalini V.
Hi @svisveswaraiya
--Sharon
slangley
(To:slangley)
Hi @svisveswaraiya-
If the previous response helped to answer your questions, please mark it as the Accepted Solution for the benefit of others with the same question.  If you still have questions, please let us know.
--Sharon
Thanks @slangley .
