Thingworx 9.2 - Tab Widget Configuration - Tab Height
Sathishkumar_C
We are using a tab widget in Thingworx 9.2.
It seems we can't reduce "Tab Height" which is available in Thingworx 8.5.
Is there any alternative for this?
sathish
6 REPLIES 6
Hi @Sathishkumar_C,
You can select the Tab Widget, Navigate to Style Properties > Base > Tab > height to adjust the Tab Height as needed.
Yes, That's okay.
But it seems, only the label size is changing. The Tab header height not changing.
Hi @Sathishkumar_C,
That's weird. I tested in my 9.2.1 environment, specifying the height only changes the Tab height, doesn't change the label size at all...
Could you please provide entities and screenshots?
I am trying to adjust the tab header size. It seems it's not meet my requirement.
check out the attached image and entity. (Green background-size needs to be reduced)
@Sathishkumar_C
I am not sure what changes you may have already have in place, I think this will do what you require.
Add the following to the Custom CSS:
/* Set the band which holds the tabs smaller  */
.widget-ptcstabset::part(tabs-header){
     background-color: lightblue;
    height: 15px;
    min-height: 10px;
/* St the size of the text on the tab to a smaller font */
.widget-ptcstabset::part(tabs-tab-label) {
    font-size: 9px;
/* make the size of the tab on the tab set smaller */
.widget-ptcstabset::part(tabs-tab) {
    height: 15px;
Please let me know if this address your issue.
Peter
Let me check at my side and update. Thanks for your support.
