Thingworx Analytics, impossible to import csv file
xavalv
7-Bedrock
Hello, I'm trying to follow the tutorial "Build a Predictive Analytics Model", I've checked that I do have an AnalyticServer configured and then while trying to upload the data in the Builder section, I do not have any choice to import csv file :
7 REPLIES 7
The File Upload extension has not been successfully imported into your ThingWorx Foundation Server. It should have been imported when you imported the ThingWorx-Analytics-<n-n>-Extensions.zip
https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/#page/analytics%2Fanalytics-install-import.html%23
Thanks for your answer Rick, but obviously the import button is not visible in Chrome but is available while using Internet Explorer.
cmorfin
(To:xavalv)
Hi @xavalv
Maybe https://www.ptc.com/en/support/article/CS286685  can help.
Regards
Christophe
xavalv
7-Bedrock
(To:cmorfin)
Thank you Christophe, as it doesn't work in Internet Explorer neither (we can fill the name fields in IE, but when hitting submit everything is frozen), so we will follow your advise
slangley
23-Emerald II
(To:cmorfin)
Hi @xavalv.
Have you found a solution to your problem?  If so, please post it here and mark it as the Accepted Solution, or let us know if you are still having issues.
--Sharon
xavalv
7-Bedrock
(To:slangley)
We had a very minor improvement : now we can fill the fields for importing the csv and json files but once we hit the submit button, the system is blocked. Here is what we have 1 hour after submitting the request:
cmorfin
(To:xavalv)
Hi @xavalv
I would recommend you open a new thread as the original issue - missing upload buttons - has been resolved.
It would be good if you could mark the relevant answer as correct. This is to help others with the same issues in the future.
For your current issue, once you have opened the new thread, upload also the resulting file from TWALogCollector (https://www.ptc.com/en/support/article/CS316782) , together with your screenshot and someone will look into this.
Thank you
Christophe
