Thingworx Flow Testing
G_U
11-Garnet
11-Garnet
As per this thread - same issue
  I am facing similar issue for testing flow execution.
To execute this flow i have configured alert as trigger from thingworx, but even after generating alert on thing I am not able to see any logs it flow.
I have tried to add logger in flow, but still not able to see any logs.
Could you please provide stepwise procedure for same?
1 ACCEPTED SOLUTION
Jimwang
(To:G_U)
2 REPLIES 2
slangley
23-Emerald II
(To:G_U)
Hi @G_U
Is it just the logging piece that isn't working?  Are other flows working?
--Sharon
Jimwang
(To:G_U)
You can refer to the below sample to test it. Of course, you can strip the tasks/nodes to make it simple.
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Integration_Orchestration/ThingWorxAlertManagementFlow.html#
