Thingworx on IE 10
Regular Member
Thingworx on IE 10
Hi
We are able to open Composer and work around.
But View Mashup will always open up a blank page.
Is there something needs to be configured on IE 10.
We are running Thingworx 5.4
Sabarish
Thingworx on IE 10
Hi Sabarish,
Does the blank page have any url? Or does it just stop loading? I tried reproducing your issue, but couldn't. Also, is there any specific reason for sticking with IE 10 and not updating to IE 11?
Thingworx on IE 10
Hi Aanjan
The page has an URL. It is just blank. We tried it on IE11 as well. Same issue on IE 11.
Sabarish
Thingworx on IE 10
Hi Sabarish,
Please do open a support case at the PTC eSupport Portal (https://support.ptc.com/appserver/cs/portal/), so that we can quickly take a look at your system and resolve the issue.
Thingworx on IE 10
HI Aanjan,
Appreciate if you create one for us. I do not know the SCN and the person who knows it is on vacation.
Sabarish
Thingworx on IE 10
Hi Sabarish,
I've created a support case for you -
Case Number  #12488757
Direct link:
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12488757
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
