Time Series Chart Design Issue
pshashipreetham
What ever changes I make in the Widget Properties the following issue is repeating again and again, the TimeStamp can't be seen totally on the dashboard, it is only half shown.
Shashi
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
So,
This issue is in 9.3.4 (latest Thingworx version) for Line Chart, this can only fixed by padding in the Style properties of the widget, in chart layout section, after certain days, Y axis was also overlapping on the X Axis, only way it got fixed is by mentioning Number of Y Axis Data points instead of keeping it auto and Increasing the height in the Widget Properties.
Shashi Preetham,
10 REPLIES 10
@pshashipreetham ,
Can you tell me which version of ThingWorx this is and what the actual widget name is?
--Nick
Hi @nmilleson ,
The Thingworx version 8.5 and it is the Time Series Chart !!
Shashi.
Shashi Preetham,
@pshashipreetham ,
Sorry for the delay.  There are actually two widgets with that same name.  Can you tell me which icon is in front of it?
--Nick
Hi @nmilleson ,
Revisiting this ticket, as of now we are using the TWX 9.3.3, this issue is still exist in Bar Chart.
Shashi Preetham,
@pshashipreetham  I tested Time Series Chart widget with TW9.3.3, but I could reproduce the issue. both timestamp and plot popup displayed fully.
Do you mind sending a demo to us?
Hi @wcui ,
Did you try in a Responsive Container ?, because we are placing the Chart on Field Set. This issue was seen. Our Dashboard is an Static Dashboard.
Shashi Preetham,
@pshashipreetham I put TimeSeriesChart inside FieldSet, still I cannot reproduce. This issue migh reply on some special settings, can you send us a demo so I can check on my side?
Hi @wcui ,
Was testing this scenario today, and I have faced the same issue. This is LineChart and thingworx Verison: 9.3.3
In the end, the TimeStamp cut off.
Shashi Preetham,
@pshashipreetham can you send us a demo? it should include mashup and data source entities.
So,
Shashi Preetham,
