Twx 8.5 Time series chart with multiple lines
LuisCabello
Hi everybody,
My problem is that I want to choose multiple items in the list and I want  the historical data of the device appear in the chart. I have a service that receive a infotable from the list and get the historical data of the devices selected. The result of the service historical data is the following image when a I put in the input 2 devices.
but I want to binding this data to the chart. When I select the 2 devices I want a line with  the historical data 'DispositivoTemperatura_1' and another with the historical data 'DispositivoTemperatura_2', but if I select 3 I want 3 lines, select 4 4 lines...
graficas.pngIs it posible to do? How?
Is necesary make a service for change the rows data in columns of each device?
Thanks in advance,
Luis.
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:LuisCabello)
It's been a few versions back since I've done this, but when I used QueryNamedPropertyHistory, the series all had different styles, they were basically the default styles for the Data1,2,3,4 etc. series.
Not sure if that Widget has changed a lot or not.
11 REPLIES 11
tdixit
(To:LuisCabello)
Hi @LuisCabello
Have you checked the Multiple Y-axis feature of Time series widget. I think it will help you to achieve your use case. Pleas see the screenshot for your reference
Please refer help center  for more details
Toolika Dixit
PaiChung
22-Sapphire I
(To:LuisCabello)
The time series chart can auto configure itself based on the number of series in the infotable.
I have done this by have a list of Properties that are logged for a Thing (GetLoggedProperties)
and then feed that into QueryNamedPropertyHistory to get selected series.
That output then goes to the timeseries chart and it will auto render.
Hi @PaiChung and @tdixit,
Thank you for reply :).
With the service that I said yesterday efectively works and as @PaiChung said it is autoconfigured by Thingworx (I had to change name of one field in the data shape and later it worked).
but now I have another question. Is it posible change the color of each line for device selected?
Remember that my service returns in this shape.
I want the temperature data line of my thing "DispositivoTemperatura_1" in red and "DispositivoTemperatura_2" in blue. How can I configure or what I have to do?
Thank you so much.
Luis
PaiChung
22-Sapphire I
(To:LuisCabello)
The time series chart should've automatically given different colors per series, not sure if you have some CSS that overrides that. You should see that in the chart properties as it should provide configuration for each series.
The very advanced and more complicated way that I believe is possible is to provide styling/css based on what is selected. I've never done this and this might be a bit challenging if you aren't familiar with CSS
Hi @PaiChung ,
thank you for your reply.
I think the problem is that the chart thinks only I have a series and this series is the data field "temperatura" en my case, as you can see in the legend label in my image.
And the other problem is that I want a legend label for each device. The mashup that I showed is a example and he hasn't have style.
Maybe I've configured in a wrong way the chart?.
How can I solve these?
Thank you.
PaiChung
22-Sapphire I
(To:LuisCabello)
Try providing a data source with the 'max' series first and configure the styles.
Then change it back to your original data source.
I believe for the labeling it can be bound?
Hi @PaiChung ,
The labeling is true you can binding. But the problem is that the styles are predefined with the data fields
no with the series. So, I don't know how to put the colors by series and not by data fields...
Thank you,
Luis.
PaiChung
22-Sapphire I
(To:LuisCabello)
Did you try what I suggested? Initially bind to it a set of data with a defined number of series, so you can configure all the series ahead of time. Then bind your actual data source to it.
Hi @PaiChung ,
Yes I try. I think that the problem is my service or if not I dont know. When you did with QueryNamedPropertyHistory you have diferent style for device's series or but data field series? I think that the styles depend of the data field not depend of the device data...
Thank you so much for your replies.
Luis
PaiChung
22-Sapphire I
(To:LuisCabello)
slangley
23-Emerald II
(To:LuisCabello)
Hi @LuisCabello.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
