Is it possible to change the background color of a page by clicking a button or selection in drop down?
yes,
You can create few css classes and on change of dropdown you can pick any of the css and bind it to css of a container. It will start reflecting.
Shyam
Hi @Sruthi
I believe you have to write your own custom CSS to achieve this
Please check below link to see how to use custom css in ThingWorx
https://developer.thingworx.com/resources/guides/css-quickstart
Toolika Dixit
Hi @Sruthi.
If you found the previous response to be helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
yes,
Shyam
