Hello All,
I was using the cloud version of thingworx, and now moved to local installation.
In the cloud one, I used to start my work by running an agent file with the URL address of my account such as below:
URI=wss://PP-2007161840G0.devportal.ptc.io:8443/Thingworx/WS
and add the APP KEY.
Now I know how to get the APPKey but not sure how to use as URI for the local installation.
Should I use: URI =http://localhost:8080/Thingworx ??
Best,
Ahmed
I tried to use the URI as below, but I got the fetal error attached. Any idea?
URI=http://localhost:8443/Thingworx
Hi @Ghandour.
Please provide the logs located at \ThingworxStorage\logs. These should provide more information regarding whether ThingWorx is running successfully. If there are no logs at that location, please provide the following:
--Sharon
Hi @slangley
Here are the logs file and the error file I get as well.
Thanks a lot in advance.
Ahmed
Hi @Ghandour.
It appears there is a problem with java. You have installed a supported version, but given the errors it's returning, there may be some corruption.
When you initially installed it, were you using an Administrator account?
Please also provide some details regarding your environment.
Thanks.
--Sharon
