Unable to add Run Time Instance permissions to SetProperties and GetProperties
eengelbrecht
11-Garnet
Good day,
I am busy adding permissions to an IoT solution my team has created. I seem to be unable to add Run Time Instance permissions to set properties and get properties. When I search for the SetProperties or GetProperties service, the service doesn't appear in the drop-down.
I am currently using ThingWorx version 8.3.2
Any help would be appreciated.
Kind regards
I have figured it out, it seems I was confused. To give Run Time Instance permissions for the SetProperties() and GetProperties() services, you would need to give the user read and write permissions for the property in question.
Kind regards
Are you using the nextgen composer or classic? How are you trying to add those permissions?
mgoel
(To:posipova)
Hi @eengelbrecht
Hope you are doing good. Could you please confirm if your issue has been resolved.
If yes please post the resolution here for the benefit of other community users. If no we can further investigate your issue.
Regards-Mohit
Kind regards
@eengelbrecht
Thank you so much for this, I Appreciate.
Regards-Mohit
