We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
As seen in the screenshot below, there are no templates to choose from when I try to create a new value stream. What could be the reason for this? I'm using ThingWorx 8.3.4-b993 trial version.
Update: The User account that I'm using was added to the Administrator User Group. After that, I was able to see the template and create value stream
Try a full refresh of your browser CRTL+F5 and see if that resolves it, if not, then potentially that is a bug, I just tried on the released version of 8.4 though and the two templates show up fine.
Hi i faced a similiar issue.
This does not seem to work. Is there a permission that is supposed to be enabled to user to allow them to go into value stream?
My users can now see the valuestream object and create a value stream without a choice of templates. However when they try to access the value stream they created by clicking on it. It shows a loading screen forever.
They probably need Visibility/Read Design/Runtime Service Execute to the ValueStream
They also will need Visibility to the Default Persistence Provider or Persistence Provider assigned to the ValueStream
How do you do both of that? I tried but it seems like its not working for my users.
Either open the entity and go to the permissions section, or go to the Lock icon.
