Unable to upgrade Thingworx due to deadlocks
htran-21
The migration process (7.4.0-b159 to 7.4.19-b262) locked up itself, took 11 hours, then hang up and no progress
I wonder if there is any workaround, or by pass the migration process cause I know this migration does not change the Thingworx database schema.
My Bests,
Hung Tran
2 REPLIES 2
 Hello Hung,
For an issue like this that will undoubtedly involve some investigation please open a case with PTC Technical Support on the PTC Support Portal so we can take a deeper look at the issue and evaluate the logs thoroughly.
This will be the most efficient way to provide a diagnosis and next steps so we can get you upgraded to 7.4.19.
Tyler Misner
ThingWorx Technical Support Engineer
htran-21
(To:tmisner)
Hi Misner,
My leader will open a case soon, thank you!
We tried once again tonight, disabled HA, route all incoming traffics to another server. Unfortunately, it is running for 4+ hours, and deadlock occurred after 2 hours running and locked up until now.
My Bests,
Hung Tran
