I have a question about the thingworx foundation anomaly detection.
Is it possible to upload a CSV or Excel file and then create anomaly alerts? If yes, I couldn't find any documentation or explanation about the subject. I understood that it's only possible that creating anomaly alerts for streaming data. Is that right?
Hi @Beyza
The anomaly detection does indeed work with streaming data, you wont be able to use a csv file by default.
You can maybe simulate this with a service that reads the csv file line by line and populate the monitored property.
Hope this helps
Christophe
Hi @Beyza
Hope this helps
Christophe
Hi @Beyza.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
