Hi ,
I have to use vertical divider, how we can draw this in TWX 8.5.2 ? i see we can easily use horizontal divider but i was not able to do it vertical.
I made it Vertical using CSS , just i applied css to existing divider and rotate it by 90 degree.
thanks
Hi @VaibhavShinde.
Without knowing what widgets you're using, etc., you might want to check for the possibility of adding a border. If this doesn't help, please provide some specifics regarding what you're trying to divide: containers, widgets, etc. A mock-up would be helpful.
--Sharon
hi,
just i am looking for dividing the widgets using divider widget, but it will be vertical line.
just see below img...wirh vertical line.
thanks
You can insert new container between two widget and change the color of container. (PFB PNG for reference)
/VR
velkumar,
i cant use this, because i already used Divider widget for Horizontal line which is a very thin line, now just i want it vertically.
why we dont have divider widget for vertical line.?
thanks
Hi @VaibhavShinde.
Per Velkumar's post, you can add a container. The container will need to be set to a Fixed size of 1 (or more pixels) as needed. You can set the color to match that of the horizontal line.
--Sharon
thanks
