Websocket connection between Thingworx and a websocket-server.
  • September 29, 2016
  • 7492 views
Hello community,
I want to open a websocket connection between Thingworx and a websocket-server for subscribing data.
I have seen that such services for http protocol exist in Thingworx:
var result = Resources["ContentLoaderFunctions"].LoadJSON(params);
So my question is:
Is there any possibility to do almost the same via websocket communication?
Thanks a lot for help,
Max
Why aren't you just using the EMS or one of the SDKs, which handle the websocket communication for you?
mrenner1-VisitorAuthor
Thanks for comment.
Yes I could handle the websocket communication using one of the SDKs.
But I thought there will be an out of the box solution for websockets in thingworx.
Do you know if there is any way to do this out of the box?
Hello
I have exactly the same "issue" :
I have to connect Thingworx to a websocket server to get data from several gateways, getting data from several devices.
I receive data in JSON format from the device ("the thing")  and send data by sending a JSON message on the same websocket.
As websocket are used internally in Thingworx I thought that there was a procedure to create a new one to connect with cloud services (which are offered more and more websockets)
So I would be interested by the solution .
Did you put a microedge server in place between the server and Thingworx ?
Is it "easy" to configure for such services ?
Thanks for information.
