Websocket connection between Thingworx and a websocket-server.
  • September 29, 2016
  • 7492 views
Hello community,
I want to open a websocket connection between Thingworx and a websocket-server for subscribing data.
I have seen that such services for http protocol exist in Thingworx:
var result = Resources["ContentLoaderFunctions"].LoadJSON(params);
So my question is:
Is there any possibility to do almost the same via websocket communication?
Thanks a lot for help,
Max
Why aren't you just using the EMS or one of the SDKs, which handle the websocket communication for you?
mrenner1-VisitorAuthor
Thanks for comment.
Yes I could handle the websocket communication using one of the SDKs.
But I thought there will be an out of the box solution for websockets in thingworx.
Do you know if there is any way to do this out of the box?
Thanks again for your help Aanjan.
I have not a possibility of accessing the server through REST calls because its a websocket communication via websocket protocoll.
When you say "If there is no API to hit/ access, we might need to look into leveraging lua." do you mean to use the EMS and write a websocket client in LUA Script?
