Which is the path to default widgets in Thingworx?
MD_10146790
I need to see how the widgets are coded to use as example for custom widgets
I have found that on previous versions they were on TomcatRoot\webapps\Thingworx\Common\thingworx\widgets
But I can't find them on Thingworx 8.5
Right now I only need the Gauge and Button widgets
thanks
@MD_10146790
I checked on 8.5.7 instance and all the widgets are located at Tomcat\webapps\Thingworx\Common\thingworx\widgets location only
Please share the screenshot of your widgets directory.
Sachin Sharma
In those folders there are only images
Open for example the Button folder, you will only see a single folder called "images"
