ThingWorx use Rhino as its JavaScript engine , but Rhino is too slow , comparing to V8 its 10 times slower , why not use J2V8 (the Java integration of V8) instead ?
Sean
Hi @seanccc.
The Product Mgmt team advised that graal, v8, et al are being evaluated for future releases.
--Sharon
You can bring your idea here: https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas
Hi @seanccc.
The platform predates J2V8. While V8 is certainly faster than Rhino, JS code in services is mainly interacting with Java objects within the platform, not executing high-performance code itself.
It's my understanding that alternatives are being discussed, but nothing definitive at this time. However, I will make sure the Product Managers are made aware of your inquiry.
--Sharon
Hi @seanccc.
--Sharon
