about Tomcat's manager Deploy
CHASEONHO
18-Opal
Hi
For some personal reason, I have reinstalled Thingworx.
I made a document of the process that I had previously installed, so I proceeded to install it by referring to the document.
Strangely enough, however, Deploy will stop Tomcat in 1-2 seconds
If i delete ThingworxStorage and backup space in the root folder and delete Thingworx in Tomcat's webbase, Tomcat will run again.
However, when you deploy Thingworx, it stops.
Thingworx used ThingWorx-Platform-Postgres-7-3-10,
Version of Tomcat 8.0.45
jdk is 1.8.0_131 jre is also 1.8.0_131
The operating system is Windows 7.
Simple ThingWorx-Platform-H2-7-3-10 is good for Deploy.
I have attached a setup ppt document that I created.
Thank you for your solution to this problem.
posipova
20-Turquoise
(To:CHASEONHO)
Have you deployed Thingworx.war through the webbrowser or copy/pasted into the webapps folder of Tomcat directory?
I'm a bit confused, is this powerpoint you created during this installation or previously and now followed? I see there are only 9 tables in the pg admin III, but it should be around 57 when both scripts execute properly. I also see that you can access the composer in the powerpoint, so the installation there is successful.
4 REPLIES 4
jdass
(To:CHASEONHO)
Hi Seonho Cha,
Please share your Application log and the Catalina log files. Does your ThingworxStorage and ThingworxPlatform folders have Read/Write permissions?
Hi Janet Joseph Antony Dass
I think this is the problem when I think!
I can not try it right now, but I have to run it on another PC.
Or I'll try it on VMware
posipova
20-Turquoise
(To:CHASEONHO)
Hi Polina Osipova
There are 57 tables in pgAdmin
Nine of these shown are made through schema updates.
