alternate for loop
Test_user
9-Granite
alternate for loop
What can be used instead of for loop to loop through 10000 records which is present in Infotable?
1 ACCEPTED SOLUTION
Ashritha
(To:Test_user)
Hi ,
If you need to find row based on some column value , you can use following snippet.
let params = {
	t: undefined /* INFOTABLE */,
	query: undefined /* QUERY */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].Query(params);
 Query can be created as in link .
Hope it helps!!
3 REPLIES 3
M4RC
(To:Test_user)
I don't know your context, however you may be able to reduce the number of calls by including the ".Array.prototype.filter()" parameter to one/both of your loops.
infoTableName.rows.toArray().filter(singleRow => singleRow.field == true).forEach(singleRow  => {
    //do magic
Ashritha
(To:Test_user)
Hi ,
let params = {
Hope it helps!!
jensc
(To:Test_user)
I think previous answers provide the information that you wanted.
But I wanted to post this here as well if it might help decide on the best way of looping: Tips-and-Tricks-for-ThingWorx-Developers-Dependencies-JavaScript
#2 in this link will provide some information regarding the different loop options you have.
Jens
