How does the multi select option work in Combo box of ThingWorx 8.2?
I have an sql query where I have given input of combo box data. I have checked the multi select but it does'nt work. Should I write any script to make it work?
Shalini V
Without a better understanding of your use case, here are a couple of articles that may help to answer your question:
Is it possible to make Drop down list multi selectable in ThingWorx 8.2
--Sharon
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
Are you binding the value and display field to a service? This is an example from a similar multi select list. Hope it helps
