dynamically create a service in ThingWorx 9.3 using JavaScript code:
Hariharasuthan
hi expert ,
this code not working i get code Chatgpt ,
var entity = ThingUtilities.findThing("ThingName");
// Create a new ServiceDefinition object
var serviceDefinition = new ServiceDefinition({
description: "This is a new service.",
remote: false,
allowOverride: false
// Add inputs and outputs to the service definition dynamically
serviceDefinition.addInput({
description: "",
baseType: "STRING"
description: "",
baseType: "INTEGER"
description: "",
baseType: "DATETIME"
serviceDefinition.addOutput({
description: "",
baseType: "INTEGER"
description: "",
baseType: "STRING"
// Add the service definition to the Thing or Thing Template
entity.addServiceDefinition(serviceDefinition);
// Save the changes to the Thing or Thing Template
entity = ThingUtilities.saveEntity(entity);
// Restart the Security service to ensure that the new service is visible to all users
var securityService = SecurityContextFactory.getSecurityContext().getSecurityService();
securityService.restart(Resource.SERVICE);
refer Create a service dynamically
Below code helpful to create service with input and output alone.
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(FieldDefinition)
var input = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    infoTableName: "InfoTable",
    dataShapeName: "FieldDefinition"
let newEntry = {
    name: "result", // STRING [Primary Key]
    description: undefined, // STRING
    isPrimaryKey: undefined, // BOOLEAN
    baseType: "STRING", // BASETYPENAME
    dataShape: undefined // DATASHAPENAME
input.AddRow(newEntry);
me.AddServiceDefinition({
	name: "test_service" /* STRING */,
	description: undefined /* STRING {"defaultValue":""} */,
	remoteServiceName: undefined /* STRING */,
	category: undefined /* STRING */,
	remote: undefined /* BOOLEAN {"defaultValue":false} */,
	parameters: input /* INFOTABLE {"dataShape":"FieldDefinition"} */,
	resultType: input /* INFOTABLE {"dataShape":"FieldDefinition"} */,
	timeout: undefined /* INTEGER {"defaultValue":0} */
14 REPLIES 14
let newEntry = {
Hi @Sathishkumar_C
thanks to support
with regards
Hariharasuthan
Hi @Sathishkumar_C
this code not put into service
Things["Gmail_Thingworx"].SendMessageWithAttachment({
cc: "harisuthanlive@gmail.com" /* STRING */,
path: "52.xlsx" /* STRING */,
bcc: undefined /* STRING */,
subject: "me test Report one mintues " /* STRING */,
fileRepository:"SystemRepository" /* THINGNAME */,
attachmentName:"52.xlsx" /* STRING */,
mimeType:"application/vnd.openxmlformats-officedocument.spreadsheetml.sheet" /* STRING */,
to: "hariharasuthan@xx" /* STRING */,
body: "Report At"+datetime/* HTML */
your share created service but not implemented below the code
created services in particular thing but empty on services how to put test services
Things["Scheduler_Dynamic_CRON13"].EnableThing();
Things["Scheduler_Dynamic_CRON13"].AddServiceDefinition({name:"hari" /* STRING */,
description:" undefined" /* STRING {"defaultValue":""} */,
to:"rr@gmail.com",
subject:"hi",
fileRepository:"welcome",
mimtype:"e",
body:"hi welcome"});
this empty on services but created services in particular services
@Hariharasuthan
As i told, the code shared is supported to create service with input and output alone.
Please refer following articles,
@Sathishkumar_C
i seen your shared  articles ,no need remote Methode just put on string values ,
my requirement  is body Serivices inside put some test ,for example
name: "hari" /* STRING */,
var result = (function() {",
    "  switch(op) {",
    "    case \"add\": return x + y;",
    "    case \"sub\": return x - y;",
    "    case \"mult\": return x * y;",
    "    case \"div\": return x / y;",
    "    default: return op in Math ? Math[op](x, y) : 0;",
    "  };",  in this code body of field put text
Just commenting out of curiosity: is there any reason why you can not add this service as a ThingShape, which you can then attach to any Thing/ThingTemplate?
I am asking this because it's not obvious where the need for variability is based on your original request.
Hi @VladimirRosu
my requirement :   this code is used to  create particular services in thing.i need to put some text code in that created services How to do this process
var serviceImplementation=me.name;
Things["Scheduler_Dynamic_CRON13"].RestartThing();
description: "welcome" /* STRING {"defaultValue":""} */,
definition:"hi welcome",});
Thanks. Do you have such a high variability of services that you can not build them ahead of time by using Composer?
Based on your requirement, I would just create a new ThingShape, add that service to it, then attach it to the scheduler.
It might be that there is a real need, but, honestly, if you will use this capability just to create 3 services overall....then it's a bit wasted time.
Hi @VladimirRosu
i had added the needed services in the thingscheduler  , i need to  write the text string in a service  through another services please suggest any other way to code
service ->myservice->actionScript is empty how to put some test using service
